so some of you might kinda know what i am doing... and for those of you who dont here you go
Parts i already have:
meth injection
CAI
exhaust and catless down pipe
centerforce clutch
dual bypass valve
parts on order:
ARP head studs
Diamond pistions
Cometic head gasket
poly trans mounts
GMPP hardened oil pump
AI performance rod bolts
GM gasket and rebuild kit
GMP neutral balance shafts
Stiffer valve spring kit (from OTT)
front mount heat exchanger
stage 2 axles
272 cam regrind
Parts still need to order:
DRs
Stiegmeier blower OR i might be getting a Harrop TVS blower...
Work that needs to be done other then install of parts:
Head is getting ported and 3 angle valve job
head and valve cover will then be powder coated red
-----Added 18 Sep 2008 at 10:26:53-----
hear is a reaser pic... i just tore down the new motor
Discussion Starter #2
damn...that thing is gonna be an animal...
