1 - 9 of 9 Posts
I've read the threads about low idle/drop in RPMs all related to a dirty throttle body. I've cleaned mine - it wasn't particularly dirty at all - I've seen pics of ones really blackened. Didn't remove mine, just cleaned with a rag from the top and under the butterfly. But if I still have the same low idle, reduced RPMs, cold weather (or very hot weather) issues - what else could it be?
Dirty MAF
If you moved the butteryfly by hand it will need to be re-programed, might have needed that in the beginning. It takes someone with a comp. And the knowledge to re-learn if you will to reset the throttle-body. Hope this helps, marcel
When I cleaned mine I moved it by hand and had no problems.. but I DID disconnect the battery. I'm not sure if that is the reason why
Battery connected or not, doesn't make a difference. The important thing is not to have the key in the ignition, not even in the "OFF" position.
I was going to say the same thing cleaned it but did take the battery off and completely remove it to clean it on my workbench.
1 - 9 of 9 Posts
