1 - 1 of 1 Posts
07 with a broken chain guide and I have ? about which parts need to replace. 2.2 eco-tec
How to tell if the cam chain and/or balance shaft chain is worn?
How to tell if any f the sprockets are worn?
Shall both chains have some slack when timing cover is off and no oil pressure?
Right now only the inner chain and sprockets are still installed and it does have some play (half Inch)
I'm certain I will replace the plastic guides and maybe even the timing chain, but I'd like to know how to tell if the gear cam and crank gears are worn out without having a new one.
Thanks.
1 - 1 of 1 Posts
