1 - 16 of 16 Posts
I'm going to B&G's and I found a really good deal on some 245/40/18's.
My question is, anyone running this size tire? If so, any issues rubbing, or turning?
If you're running this size tire, can you post a pic of how they look?
Also, is the B&G the lowest drop spring? I've been reading tons of threads but I have no definitive answer thus far...
B&g could very well be the lowest. You will be fine with a 40 series tire, but 245 is pretty wide. I'm running 225 on a 7 inch wide wheel and it's just right. I'm pretty sure it will fit but that's a wide ass tire
225 is good for a 7" rim. I have 235 on a 7" rim and the guy putting them on was mad by time he was done. 245 is too wide for 7" rims in my opinion. You should never get curb rash though from it hanging over so far lol.
245/40R18 is going to throw your speedo way too. And will probably rub, especially on B&Gs.
255/35R18 is about the same diameter as 225/40R18 FWIW
Thanks for all of the replies!
ok.. how about if I went with 225/50/18's?
Any issues there? I found a good deal on those locally. anyone running them, any pics?
What rims are you running? If your rims are the stock SS/SC, you probably shouldn't go any wider than 235/40R18. If you're rolling on the SS/TC rims, 245/40R18, although some people have gotten as wide as 255/40R18 for the TC.
Sorry. I should of clarified...I'm on after market 18's that are 7.5 wide.
SS/SC's stock rims are 18x7.5, so either 225/40R18 or 235/40R18 should be fine.
I found a smokin deal on the 22/50/18's which is why I'm asking.. Otherwise, I'm looking at paying more to have some shipped.
225/50R18's?
---------- Post added at 05:33 PM ---------- Previous post was at 05:22 PM ----------
Note: I looked up the SS/SC rims again and apparently they're 18x7's and the SS/TC's are 18x7.5.
Sorry about that.
So yeah, it appears that 245 will probably work fine then. Many of the SS/TC guys are running with 245/40R18.
Won't that **** with the speedo quite a bit? From the stock 195/60R15 it says a 245/40R18 will change it 6.3%...
I'm assuming he isn't going to ever use 195/60R15 ever again, so he can have it updated to the new size.
stock height it shouldnt but lowered it could. you might need coilovers so they dont rub.
1 - 16 of 16 Posts
