So ive searched the forums and havent seen this come up but all 4 of my tires are reading 28 on the digital display and what im doing manually but my the reader when i start my car up is telling me to check tire pressure...any suggestions?? and there not just constantly stayin at a 28 they do flex from cold to hot weather and other various things..
Put 30 in them and it will go away....
The sensor will be set off if there low by approx 2-3 psi, set the pressures to the door of the car, 32 I believe, and you should be fine. One thing you can try is Nitrogen, it's said to be less prone to temperature changes
