Ok, so i am looking at new wheels, they are steel wheels. I just have a few questions....
the dimension of the rim is 15x10.
What backspacing (1 1/2 to 7 inches) would I need to keep my stock turning radius?
next question, what size tires would i need to keep the same overall height, as to keep my speedometer correct? (I know, its a really wide rim, and Huge, non-lo-pro tires, but its what I like.)
I'd love any and all input!!!! thanks!!!!!!
As far as spacers go it depends on the off-set which you didn't mention.
What is your tire size now? So we can calculate the tire you need. Probably a 255/30 15 if they make such a beast. But honestly I don't think you will be able to fit a 10" rim. That is 3½" wider than stock. If you space it out so it don't rub inside it's going to rub outside. It might work but !!!!
P195/60R15 is my tire size now. im unsure of the offset... i can do any backspacing between 1 1/2 and 7 inches. its either that or 8 inch wides but i really like the idea of the 10's. idk. that y i asked you guys!
Your OEM rims have an offset of 42. On a 10" rimyou will need a minimum of a 255 so take it from there.
