1 - 20 of 21 Posts
Ok, my car is lowered 1.6 and 1.8 inches. I have stock 15 inch rims currently. What size tire should I get if I get a set or 16 inch rims. What tire size for 17 inch rims?
Try this tire size calculator. you can try all different sizes. Like differend widths and sidewall heights.
Tire size calculator
IMO
16= 215/50/16
17= 215/45/17
18= 225/40/18
19= 225/30/19
Discussion Starter · #5 ·
IMO
16= 215/50/16
17= 215/45/17
18= 225/40/18
19= 225/30/19
thanks obz, well thats the innfo i found also but i wasnn't sure if the lowering would effect it at all, i was using tirerack but do you think those sizes still apply if its lowered?
it should. I'm pretty sure tirerack calculates it to keep em the stock size
if ur worried about rubbing you should be ok, you car might be lowered but its not hammered, id go w/ those sizes OBZ posted
I personally would go with the following:
16=225/50 16
17=225/45 17
18=225/40 18
See a pattern here? I like 225 width, but all are fine on those sizes.
Another way to find tire sizes is by going to discounttire.com or discounttiredirect.com and inputting your car. It will give you different options for different size wheels.
You can also go to 1010tires.com and they have a tire size calculator that you can use...input your stock tire size and a few different sizes to see how much they differ.
what size rims do you have OBZ?
1 - 20 of 21 Posts
