I have a 2009 cobalt. Yesterday when I tried to leave work I was able to back out of my parking space but when I put it in drive the rpms just revved up. I had her towed home. I've put 3 quarts of transmission fluid in but still experiencing the issue. Does anyone know what it could be? Any suggestions on what else to check?
My 2007 cobalt is doing the same but I have to hit 4500 rpm before it will pull forward. Checking the ATF today and came across your post when looking for how to check the ATF on a 2007 cobalt. What did you do to get your car working again?
well found out last night that something hit the trans pan and caused it to leak so my ATF was low. bought new pan and gasket and installed them. Car now only moves in reverse not drive, L or H. I can hear it trying to pick up the ATF when I shift from Neutral to drive.
