1 - 8 of 8 Posts
Discussion Starter #1 (Edited by Moderator)
People,
Checked the greenish 20A fuse for trunk in engine bay and it's good. Trunk button doesnt even click when depressed. Where should I start? Checking for power at wire just behind the button with test light?
Thanks
Yeah, they aren't a very good switch. To troubleshoot remove connector on switch and short the 2 pins in the connector if the trunk opens you know it's the switch. On the 08 I kind of have to wiggle the button to get it to open.
---------- Post added at 11:20 AM ---------- Previous post was at 11:19 AM ----------
Be careful when removing panel not to break the switch because wire is kinda short.
Woah!! Great tips, guys!! Just tried your ideas, and turns out the button switch does work!! I jiggled the switch around, and coulda been loose or something, so popped it back in and it works great!! (for now.....)
thanks!!!
Make it harder for theives I guess
1 - 8 of 8 Posts
