im close to change my oil againg and im using Valvoline Synthetic 5w-30 and my car has 70289miles already should I still use the synthetic or should I start using High Milage synthetic..........should I change brands........which bransd are better....and also im also going to change my spark plugs are there any special care before and or after changing them.........
I work at Valvoline I change oil all day everyday my advice would be to start using the maxlife full synthetic its awesome we hear nothing but good things about it as for brands mobil 1 and valvoline are rated 1 and 2 on the scale so id stick with what you have been using
You'll be fine running synthetic still.
Nothing real special you have to do before or after plugs...
For the money it's hard to beat mobil-1...walmart sells a 5 qt jug for $23.
For plugs check the gap even for pre-gapped plugs just to make sure they're within spec. Also always use anti-seize on the threads and torque to spec.
couldn't have put it better myself... :-D
