1 - 9 of 9 Posts
I've found several posts here about people adding superchargers or turbochargers to their 2.2L Cobalt. I want to add a little extra hp (about 50 hp, or a 30% increase), but as a college student funds are limited.
If I found a supercharger from the supercharged coupe SS Cobalt at a junkyard, could I Jerry-rig it onto my 2005 2.2L? (provided I purchase any necessary gaskets, tubing, etc) Or are there complications which make this ridiculously impractical?
I'm an engineering student so if I need to run calculations concerning airflow, energy, heat, etc that's fine by me. I also have access to a machine shop if I need to modify parts to make this work. Just trying to get my 145hp engine to about 200.
P.S. If there's already a thread on this that I missed lmk so I can delete this one and not clutter the forum.
Yeah, the supercharger swap is definitely easy to do, and relatively affordable. There is a list of parts you'll need that I've pasted below. However, as Ryan has said, '05 will require special tuning, as nobody tunes these.
http://www.yourcobalt.com/forums/engine-mods/13885-parts-list-supercharge-2-2-2-4-a.html
Cool I had seen that list earlier but didn't realize those parts were swapped out of the 2.0 cobalt. It's a pretty great list, so props to you. I noticed you listed exhaust parts as "optional," but a friend said that if I didn't upgrade my exhaust 1st I would destroy my engine because the additional boost pressure would not be able to exit the pistons easily enough. Is there any truth to this, or could I wait on the exhaust upgrades until after I saved a bit more cash?
---------- Post added at 04:09 PM ---------- Previous post was at 04:04 PM ----------
It all bolts right on, only thing is there's no tuning support for the 05 so you would need a standalone system
If I mounted the MAF sensor at a location where the pipe diameter matched the OEM diameter so it can get an accurate mass-flow calculation, and if I located it at such a place that about the same amount of head-loss occurred between the sensor and throttle body in the new setup as the old, would the readings be accurate enough that I could get by without a tune? Or am I just asking for my cylinders to be shred to pieces?
Any truth? Not even remotely.
I ran an entire stock exhaust - manifold, downpipe and exhaust system for probably a year or so before I upgraded to an SS/TC exhaust. Then about another year later I added the header and downpipe to complete the system.
So you absolutely can wait on that if you'd like.
If it would even run, it wouldn't hold up very long if you supercharge it without a tune
Yeah - it would dump so much extra fuel into the cylinders, you'd wash the bore walls down and dilute the oil - which leads to boom.
What if I installed a variable fuel pressure regulator to mechanically restrict the fuel to the proper amount? Between that and strategically manipulating placement of the MAF sensor, it seems like you could find a balance but I've never had the privilege of viewing the ECU's code to know for sure how the calculations work.
If you restricted flow, then you wouldn't have sufficient fuel flow for when you ran into boost.
1 - 9 of 9 Posts
