What? Do you mean a resistor on the turns so it doesn't hyper blink?
Some cars have a bulb out warning light. The Cobalt doesn't have it, so the warning cancelers aren't needed. Be sure to use a relay harness. While we're on the subject of projectors and HIDs, don't go with those headlights. Better yet, spend the extra money and build yourself a retrofit. Those halo projector lights are actually designed for halogens. You'll get much better light output by putting HIDs in projectors that are meant for HIDs. If you still want to go with those headlights, then consider getting a Retroquick kit from The Retrofit Source so you can swap out those crappy halogen projectors for Mini H1 bi-xenon projectors.
I bought a set of TYC stock headlights and did my EvoX-R retrofit in them. I had to swap the reflectors over from my original headlights because the TYC reflectors are very brittle. So I was able to work on my retrofit a little at a time and still drive my car.
