Hi i have a 2010 cobalt lt driving yesterday went to turn on wipers they didnt work,found wiper fuse blown in center console fuse box so replace wipers work than push washer switch it blows fuse again. So i can use wipers but if i try to use washer it blows.
Any ideas problem?
Thanks
Your windshield washer fluid pump motor has probably shorter out. It just snaps to the side of the washer fluid container. There's a rubber "O" ring used as a seal and one connector on top. Very simple to change.
---------- Post added at 12:37 PM ---------- Previous post was at 12:36 PM ----------
Disconnect the motor until you get one so you don't accidentally blow the fuse again.
Cool thanks for reply and for posting a how to that helps alot. Ordered new motor and disconnected
Thanks again
