GF And I went on a trip. Left her 07 cobalt in long term parking at the AP. While we were gone, they got about 5 inches of rain. Passenger floorboard was full of water. After it dried out, I ran it through a. Car wash to check it out. It is coming in about midway on the door opening...bottom. If you look at the inside lower part of the door itself, you will see a seam, or indentation or something. I don't see any rips or any other abnormalities in the weather seal that would allow water in. Any ideas?
When you close the door see if the seal is seated properly. Pretty much make sure it's not loose. It should be stuck on the door. I had this problem with my previous car. There's not much that can go wrong with a seal. Unless the door is bent
2005 cobalt base model coupe
