I have wet floors in my 06 Cobalt I'm sure is an HVAC drain plug is blocked, I found the drain hose on the firewall per colby but I can only get something in about 4 inches. Is there a way to get from the inside?
Hard from inside because you can't see. 4'' is probably where the blockage is, keep poking until you get a shower.
I blew some air in the hose and water came out so I think it's clear .coby you are the man. next question is the air conditioner always running it seems like it's not cycling off and on?
It may work differently now that you have cleared the drain but if it doesn't have it professionally serviced.
