1 - 17 of 17 Posts
i went to start my car and it took ten differnt times then it finally started and the tachometer sat at zero then went up and down, then went back to normal.
anyone know how to convert to miles. id suggest getting an induction clean, run some shell in it for a few weeks. itll clean out the system, and just for a check up make shure your battery conections are tight, its in the trunk next to the spare
that happened to me once too.. just once and i hasnt happened since so i just assumed she was havin a bad night.. lolz i didnt realize it was a real issue.. goodluck with that =(
this is a really really big problem with the newer gm 3.4... (chevy cross over engine..) it has something to do with the ignition timeing modual.. im not sure if this is related to your problem
1 - 17 of 17 Posts
