Should be on the back of the engine below the thermostat housing. You probably wont actually be able to see it but feel around for it back there and you will find it
Thanks for replying. I heard about the thermostat hosing too. Can I see a picture of a thermostat housing? I uploaded two pics. Where the arrows are pointing, is that a coolant sensor? If not, what is it?
19594
19595
Wrong side. Thermostat housing is on the back next to the exhaust manifold.
That's the crank sensor
Pretty much that same area but back by the firewall. Like I said you will probably just have to feel around for it, not sure you will really be able to see it
Yup rear side of the engine towards the driver's side.
The side facing the firewall is where you’ll find it. It’s located inside the thermostat housing. Closest to the transmission side. You can see in the pic that the exhaust manifold is right above it. In your pic that is the oil pressure sending unit.
19596
19597
