You will want to save up and do your entire suspension all at once to save on alignment costs.
You will need FE5 struts and shocks from an SS/TC... found at crateenginedepot.com
Next you will need lowering springs.... pick your poision
Next is the sway bar, your choice of TC or SC.. SC is larger by a couple mm's... also found via CED.com
Next you will need endlinks... most go with Moog, but there are adjustables out there
Next are bushings (trans, sway bar, possible control arm) engine as well if you wanna get serious... TTR has trans (as well as many other places), Moog for sway bar, and depending on your performance goals Moog or OTTP for control arms.
Lastly is the control arms. You will need FE5 from an 05-07 SC model. If you go 08+ its from a TC and has setup with your knuckle.... hard to find for cheap, I go to pamsauto.com and call CS, they typically can find you a set for a reasonable price.
