The car is a 2009 Cobalt LT Sedan. It recently just started making a loud whining sound, very similar to the sound of a failing power steering pump. The sound is coming from the top end, near the timing chain and cam gear area. It does not do this on cold starts. It only starts once the car is warmed up and driven for a couple minutes and only at idle speed (also coasting at idle speed). If you give it the slightest bit of throttle the noise goes away completely. I have a video of it but the forum won't let me upload it in MP4 format.
No codes are being triggered and it seems to run just fine. But it is parked for now so it doesn't potentially cause a larger issue.
Any ideas or suggestions?
