1 - 11 of 11 Posts
Hi all- I just bought a '08 Cobalt Sport and LOVE IT :bigsmile:
However...the sunroof will start whistling when going 65+mph. Is there anything I can do do fix this? I tried to re-adjust the sunroof, but it will not go down any lower. Also, should there be a little square rubber thing in the back of the sunroof propping it up a bit? It seems like the air is leaking because of that. (Factory sunroof BTW)
Thanks in advance!!
does yours go up a bit if you push on it in the back? also, if you shut the doors, does it pop up briefly? I'm wondering if it isn't shutting all the way...
I was afraid of that...anyone know how to adjust these? I already bugged the dealer where i purchased it, but they said it was normal :unsure:
how cold is it there? mine did it when it was well below freezing outside but its like 50-60 degrees out and it's stopped doing it
hmm maybe that is part of it..it's getting to -10F at nights and usually around 20F during the days here. I think I still might mention it to the dealer again..the thing seems too loose because I can push up on it lightly and it'll go up about 1/8 of an inch. Also the car has 48K miles on it, so I only got a 3000mi/3month warranty.
Bamble Ramble!!!!
I have the same problem, I think it's just the cold weather, it never did that during the summer months
You may have to give them crap about the TSB on it. They prob will neglect to mention it.
Discussion Starter #11
does anyone have the TSB # or info on the TSB? I didn't buy it from a Chevy dealer so I'm not sure if it'll help or not
1 - 11 of 11 Posts
