1 - 10 of 10 Posts
So I just swamped out my old pioneer unit for the jvc kw-av61 and I noticed a huge difference in sound quality. Anyways I want to hook up my subs and there seems to be only one dedicated sub out female instead of two for the RCA cable. Do I have to by an adaptor or just plug only one RCA in there? Thanks in advance for the help!
Since there is no stereo component in bass you only need one output. You can use a "Y" splitter to the input of the sub amplifier.
Yeah, what ever ends you need to connect your sub.
Levee
Why not use the rear ours and just adjust the amp?
Levee
Most CD players (shoot even aftermarket cassette players) have Front and Rear, or just Rear RCA outs. You can run your Rear set to your amp for your subs, you just have to make sure the amp is in LPF and adjust the Frequency response on it to make sure you're not getting anything the sub shouldn't get.
you could do that, but a dedicated sub output is always preferred...it will have the LPF built in, and most radios will even give you the option to choose the crossover frequency and sub level on the radio
most sub amps will be wired mono as well, and often if you just plug in the right or left input (depending on the amplifier) it will play without needing the Y-adapter
1 - 10 of 10 Posts
