1 - 14 of 14 Posts
Fig. 17: View Of Wiper Arm Nut & Cover
Courtesy of GENERAL MOTORS CORP.
1. Turn the ignition ON.
2. Turn the wiper switch to DELAY.
3. Turn the ignition OFF when the wiper arms are paused at the bottom of the wipe pattern.
4. Remove the wiper arm nut cover (1).
5. Remove the wiper arm nut (2).
Reinstall in reverse.
1. Install the wiper arms onto the wiper transmission pivot shaft.
2. Align the wiper blades ends to the alignment dots in the lower windshield blackout
also you might need a special puller or something to pry on the arm with cuz they can get really stuck on that shaft
Discussion Starter #12
You know that isn't a bad Idea on painting the arms, the black the factory paints them with has worn off on mine and now they look a charcoal gray and rusty color.
that's why I'm going for since mine are grey and they should be black so painting them as soon as get those babies off...:)
1 - 14 of 14 Posts
