1 - 20 of 29 Posts
I see this repeated frequently on the forum, so I decided to write up an how-to on the easiest way to wire the 4 factory location speakers (Mids/Highs) in your cobalt to a 4 channel amplifier
I worked as a car audio installer for over 14 years, and have done this method more times than I can count, with amplifiers up to 500 watts/channel with no problems, although I'm sure I will get the usual "but the wire is not heavy enough for the amplifier power" arguement. Use your own judgement, but I can tell you from experence, that it is not a problem. After all, look at the tinsel leads on the speaker, they are usually 18ga or smaller, if they can handle the power, so can the factory wiring.
this will of course, also work with the factory speakers as well, but a high powered amp will likely destroy the cheap factory speakers, so a speaker replacement is recommended
this method will not work with the factory amplified systems, you will have to wire to the front speakers themselves (or to the amplifier location, which is under the steering wheel, I think it would be just as easy to wire to the speakers themselves)
If you are not sure if you have the factory amplifier, here are some tips:
do you have the factory sub...well then you have the factory amplifier.... :)
when you pull out the radio...plug in the adapter harness before making the modification below, get any one of the speaker leads...say the Gray (+) Gray/black (-) Right front lead, and touch the wires + and - to a 9 volt battery...if the speaker makes a pop sound, you do not have a factory amplified system, and this method will work for you
Step 1:
remove your radio of course, this method works with an aftermarket radio, but will also work if you use the factory radio, and cut the speaker leads and wire a line output converter to the radio side for the RCA output to the amplifier
on the adapter harness, you will have the ( 8 ) speaker input leads
White (+) White/black (-) Left front
Violet (+) Violet/black (-) Right Rear
Green (+) Green/Black (-) Left Rear
connect the wires as follows:
Gray (+) to Violet (+)
Gray/Black (-) to Violet/Black (-)
White (+) to Green (+)
White/Black (-) to Green/Black (-)
the end result should look something like this:
I have pictured a PAC audio C2R-GM11
of course, you would heatshrink, tape, or otherwise insulate these wires
you have now created a circuit in which your rear speaker leads are connected directly to the front speaker leads that are already running throughout the car (do you get where I am going now?)
you would not connect the speaker outputs from the radio, isolate those wires to keep them from touching each other or grounding out
Run a single conductor wire (usually at least 16ga) from the amp turn on lead of your radio (usually dark blue) or if you still have a factory radio, find the power antenna lead (some will also tie to an accessory fuse in the fuse box)
run the RCA cables and the remote turn on wire into the trunk
Mount your 4 channel amplifier somewhere in the trunk of your car... I put mine right on the rear deck
Run the power wire with fuse directly from the + terminal of your battery in the trunk
Run the ground cable from your amplifier to a bolt on the chassis, but be sure to clean off all paint where the eyelet will mount to the chassis for a good ground connection
connect the previously run remote turn on wire to the remote lead on the amplfier, and connect the RCA's to the input of the amplifier
Remove the speaker leads from the rear speakers, you can then either cut the connector, or use an adapter harness such as this:
Metra Part # 72-4568 | GM wire harness | Metra Online
Connect the body side of the rear speaker wires to the front leads of the amplifier, the left rear connection is now the left front, right rear is now right front
Connect the rear output leads from your amplifier directly to the rear speakers
start the car, turn on the radio, and adjust the gain controls of the amplifier
***I say to start the car for a couple reasons, firstly, if you have engine noise through the speakers when the car is running, it can be removed many times by turning down the gains on the amplifier, if this does not eliminate it, check your ground wire on your amplifier, a bad ground will often show itself with amp noise, if these fixes do not work, try a ground loop isolator, such as this:
Amazon.com: 4 Channel Ground Loop Isolator: Computers & Accessories
also, this can take quite a while to get the sound right where you want it, if the car is running, you won't kill the battery, but be sure whereever you are doing this is well ventilated from exhaust gasses
re-install the radio, and enjoy having much cleaner, louder mids and highs!
by combining them, you would just use the wiring that is already in the car, and use the rear speaker leads to connect to the amplifier for your front speakers
---------- Post added at 12:23 PM ---------- Previous post was at 11:44 AM ----------
I don't see the advantage to speed cable...
you would be wiring all 4 speaker locations, running them 20 feet to the front of the car, and then running them to their final locations
this way, you are just running to the front speakers, and then connecting directly to the rears
No I get that, saves running 2 new sets of speaker wire to the back, but why are you mixing the front and rear speaker lines at the deck?
Rear speakers you dont touch as the wires and amp are right in the trunk already, fronts can go from the front outputs at the deck to the rear speaker lines at the OEM harness, then cut at the rear speakers and that wire run into the front out at the amp, turning the rear OEM speaker line into amp'd front speaker line.
But you have the front and rear speakers lines twisted together at the deck harness for some reason and thats whats not making sense to me....you dont use the deck speaker output wires at all when using an amp, so what are they doing?
I'm not twisting anything at the deck itself, those wires you see in the pic are for the harness into the car
the wires coming off of the deck are isolated, and left unconnected
gotcha, makes way more sense now. I thought you were going to connect them to the deck like that for some reason. now I see its just the junction of the rear speaker wire going to the front speaker wire.
Hmm..
Combining the front and back now actually makes your 4 channel to unit a 2 channel unit, your fade option will be useless. For instance, if you had an after market DVD player unit, and it had surround, which many DVDs do, anything that was supposed to be heard from the rear speakers would be heard from the front also (and vice-versa), thus sacrificing your surround. (Some music also has 4 channels + so this would ruin a surround sound experience.
Many would not notice, probably not care either, but if that was done on my car, I would be wanting my 4 channels back.
I understand what your trying to do, the proper way would be to run separate wires from each of the 4 channels, then add some blocking diodes "before" reducing to 2 channels to support a 2 channel amp. (this way you get your 4 channels in speakers and your highs and lows for the amp)
If you have an aftermarket unit, just use the pre-outs 99% of them come with.
Johnccc, you didn't get it, he's just using the original rear speaker wires for the output feed for the front door speakers to avoid running these 4 wires. I presume the amp is a 4 channel just the same with sub out.
So...
Right front to Right Rear (those 2 channels become one now, "Right")
Left front to Left Rear (those 2 channels become one now, "Left")
We are only left with 2 channels, left and right, commonly known as "stereo".
According to his instructions he has joined the rear and front channels.
Each channel requires 1 ground and 1 positive, so for a 4 channel situation, you will need 8 outlets, I only see 4.
This would work for the amp, but would result in the rest of the system only getting 2 channels, wouldn't it?
Johnccc you're in the fog, He doesn't do this on the amp side just to the speaker wires then disconnects them from rear speakers and uses these wires for front speaker feed.
So...
no, because you connect the rear channel directly to the rear speakers in the trunk, so you would have the 4 channels coming out of the amplifier
the rear speaker leads going to the speakers on the back deck would be removed from the speaker, as per my instructions, and wired to the front channels of the amplifier,
the rear channels would then be connected directly to the rear speakers, so there will be a total of ( 8 ) leads coming out of the amplifier, ( 4 ) channels
Does the fade adjustment work when wiring this way?
Because according to your instructions and the image posted, you joined the channels resulting in only 2 channels, unless something can separate them, I don't see how you can have 4 channels anymore, this write up is rather complicated, even for me who knows how to rewire the radio system (no an expert with amps and such however). A perfect test on each channel would be to set the Balance to left, then set the fade to front, then rear, the the same again on the right channel, only 1 speaker should be active on each setting, I suspect this wiring would result in only 2 channels as right out of the unit you only get 2 channels with them joined (I'm assuming this is the harness right at the unit, correct me if I'm wrong), just my opinion.
Definately,
as long as you are using a 4 channel amplifier, and the radio has the front and rear RCA outputs, the fade will work perfectly,
I think you are confused here:
you are assuming that the factory rear speaker wiring is still connected to the rear speakers, this is wrong
the rear speaker wires are disconnected from the rear speakers, and they are connected directly to the front outputs of the amplifier
the rear outputs are then connected directly to the rear speakers
so coming out of the amplifier, you have front left and right, as well as rear left and right wiring, connected to the respective speakers
you are correct in one respect, the factory speaker wiring is only covering 2 channels, front to be exact,
wiring directly from the amplifier powers the rear speakers
I'm sorry if some find this confusing...I'm not sure how to make it any more simple
---------- Post added at 01:46 PM ---------- Previous post was at 01:35 PM ----------
you are no longer using the powered outputs from the radio, those wires would not be hooked up any longer
essentially, what you are doing with the adapter harness (the one in the picture is a PAC C2R-GM11) is creating a loop, the rear speaker wires now feed the power into the front speakers
the Head unit is no longer providing the speaker power outputs, the amplifier that is in the trunk is, the speaker leads from the head unit would be isolated, and no longer used, the audio signal from the RCA's on the back of the head unit would go into the amplifier, and the amplifier will provide the power to the speakers
there is not a head unit produced that will have outputs that are better than an external amplifier, the external amplifier is always cleaner and more powerful
Arrhh..
Its a PAC audio harness, now I see, PAC makes things magically work, I thought it was a basic harness. Now I see what your talking about.
I was about to say add that information, but I see you just did "I have pictured a PAC audio C2R-GM11".
Discussion Starter #16
any of the harnesses would work the same way, as a matter of fact, the Pac harness speaker outputs just plug directly into the factory harness, not through it's "magic box"
the harness is irrevelent, you could do the same thing cutting the wires behind your radio
Discussion Starter #17
I'm not sure if this will help or just confuse more...
but here's a diagram explaining what I am doing
the junction where the front/rear wires meet is done behind the head unit
once again, I'm not sure if that helps, but apperently I can't explain this clear enough
:ROFLOL: Pretty clear ...... :ROFLOL:
Discussion Starter #19
I have mad diagram skills yo!
:nahnah
Arrhh..
This might clear things up...
The rear speaker wire is being cut at the back of the car and rather than goin to the speakers, its now going to the front speaker output on the amp. New speaker wire is used from the amps rear speaker output to the speaker side of the oem cut wire.
Then the oem rear speaker wire (plugged into front spk out on the amp currently) is twisted together at the wire harness to the oem front speaker wires also in the harness, making one connection from the amp to the front speakers using all oem wire.
Audio input t the amp is made via rca's so fade and balance will work like usual
1 - 20 of 29 Posts
