1 - 12 of 12 Posts
In the valve body?
---------- Post added at 06:18 AM ---------- Previous post was at 06:11 AM ----------
If I down shift when i get to the speed I want to be at it won't shift back up into the next gear unless I put it in the gear shifter in I then it goes in that gear the back to drive then it will up shift again. About 1500 miles ago I had the valve body all the valves and torque converter replace by dealer under warranty due to the tranny surging. Sent from AutoGuide.com Free App
Levee
Has it done this since the dealer worked on it? Like it all started when they worked on it?
Levee
Could it be because we set the governer at 73mph?
---------- Post added at 08:47 PM ---------- Previous post was at 08:46 PM ----------
Hptuners. What did you do to fix it?
73 mph? You mean 7300 rpm? I brought the rpms down on the govern. Go to high and it won't shift right. At least that's what my car did. Trifecta tune
1 - 12 of 12 Posts
