1 - 9 of 9 Posts
K
Guest
:mad: The XM band has quit on my 2005 -- all the radio will display is AM and FM bands ... has anyone else had this problem? Also, the inside fuse panel diagram in the owners manual and on the kick panel is backwards!
Wow that is weird...I'd call XM and see if they know what it is...
M
Guest
did you accidently put all your presets to am and fm channels?
M
Guest
even with a paid bill it should still tune XM channels, but all you get are "commercials/adds" for all the diff stations
turn it over, or use a mirror, SOLVED!
does it still display XM as a band when you push the BAND button? is XM still there and just not playing or is it gone?
Well I cancelled my subscription today for the XM and it still shoes when I click band but it will only go to channel 1 even if I try to switch, you should give XM a call
1 - 9 of 9 Posts
