no, the gt28 kit would allow u to beat a stock sc but not a stg2 sc, and a tc would continue to kill u. bigger displacement isnt everything, u need parts to back it up. LSJ and LNF is a much better built engine and therefore will handle mods a lot better.
what kit could i put on my 2.2 in order to not void the warrenty
none sadly, lol. u could put the m62 on there and try and pass it as being a ss/sc next time u go in for service though, lol. dont think that would work either though...
correct me if I'm wrong, but can't you get more power from turbocharging a 2.2 than a stock 2.0TC?
no, u will get in the 220-240 range.
alright, im gonna clear some stuff up for u guys, since this is wat ive been looking at for a LOOOONG time since im doing an sc m62 build. heres the fastest 4 2.2Ls i kno of that use some form of forced induction:
Stenguyen1 - 260whp Verfied DynoJet 2.9, Dual pass, Heat exchanger, Intake, Header, Exhaust, Cams, Cat Delete, 60#injectors, Tuning, Ported Blower, M62
xCobalts05x - 258whp 215wtq verified dynojet Turbo Kit, Header, Dual Pass, 60s, Tuning, Intake Manifold - i cant verify which kit, i think its the zzp one though
mkurlrey13 - 241whp 254wtq Verified Dynojet Turbo Kit, Dual Pass, Exhaust, Tuning - this was the garret kit with a think a few extras that he changed on it
Sw4y1313 206 whp, 220 wtq - 06' RY Cobalt 2.2 Turbo (#'s @ 17psi COMING SOON)
Custom 3" Magnaflow Exhaust(Catless)
Wiseco Pistons(8.9:1), Eagle Rods, ARP Head Studs, Cometic Head Gasket, Exedy Stage 2 Clutch, Vulcan Intake Manifold, Siemens 60lb injectors, NGK LTR7IX-11 Plugs - those numbers were at low psi, but as u can see he used internals too for some reason
heres the failure points for most of our parts:
stock rods - 250-275 hp
stock pistons and/or rings - 300 hp
stock crankshaft - 350 hp
valves - 275 hp
if u have an auto - 365 hp
hope that helps. i chose to go m62 supercharged because i will not need to do any internal work and i can still have a car thats reliable but very quick. ill prolly end up replacing the rods w/ eagle forged ones just for safety purposes though.
EDIT: shit i forgot about hunterkiller89, his build is pretty much wat im basing mine off of, lol.
hunterkiller89 - 265 bHP(prolly around 240 to the wheels)
GMPP Exhaust, Auto Transmission Mounts, ZZP Mid-Length Header/DP combo, Hayden Transmission Cooler, AEM Fuel/Ignition Controller, AEM UEGO, M62 Blower, ZZP Heat Exchanger, Option B
