21 - 40 of 101 Posts
I got it too work, now... the head unit is too big in the backk... what do I do lol
well me and my friend cut some of that plastic thats in the way...but i mean thats up to you. we just trimmed a little of it off but didnt completely remove it
Save
Discussion starter · #25 ·
my head unit was maad tight too especially with the wiring harness. I tucked the harness beneath it, and there's like this shiny metal tab all the way in the back of the dash opening, that like does nothing, you can push on it and it will bend a bit, and i bent it enough to give myself a bit more room. Then just put the double din in and play around with it until you ge3t it to go in at a good position (this may take a few mins but itll go in) then put them screws back and tighten (but not too much!)
One problem i have though is when i wanna insert a disc, i press the button to open the unit and it is tight on the top so it wears on the motor abit more thna it should when i open it. Not a huge deal for now because i barely use CD's (IPOD cable FTW) but i think l8r on imma try to fix this by taking out the head unit and screwing the dash trim a bit higher on the unit.
Save
very helpfull write up. I to am going to be installing a double din in my 09 cobalt and i seen from the vid that you still have door chimes but did you loose anything since i seen your harness didnt have the onstar (like the digital display on dash ect.)
Save
Discussion starter · #28 ·
my car doesn't have onstar. If you have either onstar or the premium pioneer system, then there is another harness (same harness but different model number) with the wiring required to retain the onstar. I did not lose any of my other stock features, though. everything works exactly like stock head unit, the radio even stays on for 10 mins after the keys are removed or until i open my door.
The install for the onstar harness should be almost the same besides a wire or two for the onstar. check on crutchfield for the proper harness info. the harness comes with a decent wiring layout guide so should nto be too much more complexe.
Save
Discussion starter · #29 ·
STICKY!!! i keep re-posting the link for this thread simply cuz ppl repeating the same install questions and it's annoying to find the thread numerous times :D
Save
Discussion starter · #33 ·
that helped alot but you have to have a dash kit install to fit any aftermarket dvd player right?
that is correct. They are cheap. I don't suggest you skip out on buying any of the suggested components since it makes installation much easier and retains all factory warning chimes, aux power, etc.
Save
Great write-up. This will help me tremendously this week when i install my new deck. Thanks
Save
Great "how to" now I know what to expect when I tear into my balt. I am installing a touch screen Pioneer after I get my tax return lol. I think the harness adapter you used is the same one I am gonna order. do you need another adapter for the steering wheel controls or does that adapter take care of it?
Save
Hey guys I was woundering If I could get a more detail with the wiring part of this how-to. I just dont get the part were you are doing the wiring from the Interface to the head unit.
By the way I have a 2005 Pontiac Pursuit. Its basically a Cobalt. I know I could go the cheap way, but I dont wanna take any chances, because people are saying if you dont get the interface that your airbags might not deploy in an accident. and there a whole bunch safety hazzards.
I also dont understand what you mean by this. Do I need any special hardware? and how exactly do I do this.
Now, the CR2-GM11 comes with a red accessory wire, which connects to the head unit in order to give it the capability of working like your factory unit and staying on when the car is off until you open your door etc. It is easier than going to get the accessory from the fuse box to turn on the head unit. The wire is max 1 amp, however, and in fear of damagin the new interface, i followed the instructions and put a relay on the interface's accessory wire and then connected the head unit's accessory to the relay, I went and got the relay's main power from a fuse in the fuse box (20a I believe) and it works like a charm. The interface has instructions on how to put a relay if you think your unit will need more than 1amp accessory. If it doesn't, just connect red with red on the harness and you<re done this step. Heres a pic of the relay i installed;
Really I am new with audio and cars. and I just wanna do this right. I really want the experience and I wanna learn how to do this correctly.
So ya any extra info that you can give me would be most helpfull
Thanks
Curtis
Discussion starter · #38 ·
Nice pics ericnerica! And for steering wheel controls there is a sufferer model of adaptor available from crutchfield. You can chalek the PAC website to get the harness' product code, but crutchfield should be able to tell you which one you will need.
Save
hey man i also hve the same question about hooking up the relay please get bck to us as soon as u can man this install has been bustin my balls for a while now thanks
Ya I just bought all of my gear and I will be putting it in tomorrow. Anything else I should know before the install.
You have insufficient privileges to reply here.
